melred
Hi all, I've been through the forums and every other link for this problem and it seems im not the only one, but cant seem to find the "correct answer". I have a Pro-97 , 20-157 and rs 800mhz rubber duckie. Im trunking this system...http://www.nf2g.com/scannist/index.htm
Now I can hear the buzz on 2 of the controll channels ...856.3375 and 856.5875 and im trunking both at 99% with the rs 800mhz duckie.
So my question is am I suppose to lock out theses control channels or not. When I scan the bank nothing ever happens, yet when I go through manually I can hear conversations.
Obviously with the control channels not locked out in scan mode it stops on them, yet with them locked out I hear nothing in scan mode.
I have win97 (thanx Don for making life that much easier..lol) and the bank is set as follows,
1: All the control freqs in the link above are entered
2: I have not programed any of the talk id's
3: The bank is set to Mot
4: The bank is in open mode
5: It is set to normal 800 mhz
6: My custom trunking table has a base freq set to 851.0125 with an offset of 380 and step of 25.0.. (not even sure if I had to do this but it worked)
so again, everything works fine in manual, but nothing during scan. Help!!!!
