Antenna+Drop amp + RG11 = Correct?
webstar22
RenfrewCountyScanner.com
Ontario, Canada
Sorry for the crude picture but I am wondering if this is the correct wiring for what I am doing. Also for the grounding line on the Rg11 cable. What should I connect it to on each end. I am not sure if I should go from the amp a the scanner or a copper pipe in the house etc..
N
N_Jay
Guest
Looks good.
Ground everything.
Only problem I see is you are using "fuzzy" coax.:lol:
webstar22
Ontario, Canada
N_Jay said:
Looks good.
Ground everything.
Funny, haha.
If I just run the messenger wire on the coax from the antenna, to the amp to the grounding in the house that should be ok?
trooperdude
SFO Bay Area and Las Vegas NV
RG6-U Quad Shield should be your minimum coax.
Ground EVERYTHING to a common ground. 8 ft copper clad rod hammered into the ground near the antenna base.
LordJ
South-Eastern, Ontario
First off just a general WHY? about the drop amp...just curious.
The antenna should be grounded at the base of the mast/tower, (when I say grounded, I mean cable to a ground rod into the ground. Search this, and you should find instructions and such) The feedline should have a lightning arrestor inline somewhere. The drop amp could be attached to any normal ground you can get from inside the house. This s simply for static dissipation. Simply connecting the entire system to an electrical ground will do nothing for lightining.
