Antenna extension?
morustyfan2
I have a BCD436HP. I can’t have an outside antenna in my neighborhood. I would like to possibly get the SRH77CA to suction to a window. What kind of cable would I need? SMA male to female? Thanks so much for help!! ~Lisa.
lou9155
shamong nj
imho i dont think that will make any difference in reception. you need to be outside the confines of your walls at least . can you do it stealth ? maybe a mobile antenna hidden in a garden?
morustyfan2
Ohhhhh that’s an idea! I could just call it art :). Thinking.... Thanks for the quick response!
riccom
My wife and kids said i have to many radios!
Yankton, South Dakota
How about Attic mount antenna?
Sent from my 5049Z using Tapatalk
popnokick
Northeast PA
Put one of these in your window facing the direction of what you want to listen to (as pictured) -
https://www.walmart.com/ip/1byone-T...6-5-Feet-Coaxial-Cable-Silver-Black/516050140
... or any of similar other flat panel antennas. Yes, it works on scanner frequencies as well as TV. You'll need an adapter like this to go from the cable on the antenna to your BCD436 -
https://www.amazon.com/MWRF-Source-...30275760&sr=8-4&keywords=sma+male+to+f+female
Rotate the antenna on the window for the clearest signal before you stick it onto the glass.
