I'm planning on at some point down the road mounting a Slim Jim copper pipe antenna in a permanent location on a mast. Everything I've read recommends directly grounding the antenna and the mast via a ground wire to a ground rod for safety, which makes sense. And also the antenna can be in direct contact with a metal mast.
What I don't understand and would like someone to explain is how does this not affect reception? I obviously don't have a good understanding of how this works, but the electrical understanding I do have would make me think that any signal the antenna picks up will take the path of least resistance which would be to ground and not to the receiver. So how does this work?
Thanks!
Thanks!
