Antenna mounting and metal roof
tpribble
I'm looking to install a base station in my house. I looking at possibly using and old adjustable Directv wall mount and a few links of mast to raise a Anton 99 over the low edge of my roof line. My question is since I have a metal roof, and the peak of that roof will be higher than about 50% of the antenna will it affect reception and transmission severely?
prcguy
It will probably affect it some. Do you have a vent pipe sticking out of the roof near the peak you could mount the antenna on?
prcguy
tpribble
The vent pipe is low on the roof also, I would gain maybe a foot more clearance at the most. I could extend the mast higher but I live on a hill and 50+ MPH wind gusts are not unusual several times a year. I even considered mounting it on my flagpole but I question of the aluminum pole can withstand the extra mass in a windstorm
prcguy
How about planting a 3ft antenna tripod at the peak of the roof? You can usually measure and locate rafters or just drill holes for the tripod feet while someone is in the attic with a couple of 2X4 scraps and run lag screws into the 2X4's, sandwiching the roof.
prcguy
jonwienke
More Info Coming Soon!
VA
Yes. Get the bottom of the antenna above the peak of the roof, or you will have crappy reception on the side blocked by the roof, and probably high SWR issues as well.
I would suggest a mast along the end of the house centered on the peak of the roof, concreted into the ground at the base, and attached to the eaves or side of the house near the top. That will minimize stress on the roof and minimize the possibility of causing leaks, and also help direct lightning strikes away from the house in the event of a direct hit.
