doctordave said:
Mike,
I used a commercial (high cost...forget the brand name) pre-amp some years ago and found that it caused horrific overload on 800, much noise in the 150's and maybe a slight improvement on 40 MHZ. Overall, I was very, very un-impressed....much like what others have alluded to here. For me, in Baltimore County, simply going with a high-gain 800 MHZ antenna (up from an average tri-bander) caused so much overload on 800 that I could barely copy the trunked system. Interesting concept that too much signal can actually be a bad thing in some cases.
Dave
Signal level is not the issue.
You have signal to noise to worry about,
and adjacent channel and out of band desinsitization,
nad receievr quieting due to noise on the image frequency,
and non-linear mixing products in the amp and receiver.
Commercial systems never use an amp without a filter in front of it, and often have a filter after it.
Typically the gain of the amp is set to only slightly more than the loss through the filter and line.
The idea is as much to reduce the noise as it is to increase the the signal.
