Antenna Purchase Help
Ishyid
Bonney Lake, WA (Pierce County)
Hi,
I own a Pro-162 portable scanner. I am looking for a new base and mobile antenna around the 100 dollar range each. I am looking to scan 100mhz to 800mhz. In your guys opinion, what is are some fesable antennas that wouold do a great job.
Thanks,
Josh
hoser147
Grand Lake St. Marys Ohio
Check out the Wiki there are lots of antenna info and links there. As far as the base antenna just remember to use good coax especially for 800mhz. Do you already have a tower or mast?
Ishyid
Were can i get some good coax? And how does the coax make a difference? And is it the same type of coax as you use for the TV cable? And no i don;t have a tower or a mast.
hoser147
If you want to stay within the amount you have budgeted, you might take a look at the Scantenna ST2 it comes with coax. Then you would have to see what kind of mount and mast you want to go with it.
