Antenna question....
wthclt
Greenwood, VA
Would a 4G LTE sma antenna work to pickup 800mhz? I would use it on HomePatrol 2. Just curious.
Thanks.
CT
Yes it would work - but so would a paper clip.
It's the wrong wavelength.
Mobile 4G network uses several frequencies:
700 MHz (Band 28 - Telstra / Optus)
850 MHz (Band 5 - Vodafone)
900 MHz (Band 8 - Telstra)
1800 MHz (Band 3 - Telstra / Optus / Vodafone)
2100 MHz (Band 1 - [a small number of Telstra sites] / Optus [Tasmania] / Vodafone)
2300 MHz (Band 40 - Optus [Vivid Wireless spectrum])
2600 MHz (Band 7 - Telstra / Optus)
You're better off with the stock antenna or an external scanner antenna.
IC-R20
LoBand Nation
Thanks for explaining that.
No it would actually work fine. It's within the right frequency range and people do it all the time for scanners since 1 you can get them cheap 2 you can work them a lot wider very easily since it's receive only.
wthclt
Greenwood, VA
Beyondoor LTE Duck Antenna,4G Frequency 700-2700MHZ LTE/4G Booster Wireless Folding Antenna for Network Router/IP/PC/Camera/USB Adapter/PCI PCIe Cards with SMA Rotation Male Connector,gain 5dbi https://www.amazon.com/dp/B07PMHMLD1/ref=cm_sw_r_cp_tai_Cr.7DbHZMMCS4
so this is what I bought...works great for simulcast 800mhz on the Homepatrol 2 in my office. I have not tried it elsewhere but I believed I will get my $7 worth out of it.
cmdrwill
So Cali
