Antenna Rotators - Make-Shift
Neutrino222
Has anyone had any experience in building a make shift antenna rotator? Could you share that experience? What you used, how the parts were put together and so on. Just a basic overview is enough, but if you have the granular details, then great.
RichardKramer
Reading, PA
I used a portable work bench, the older heavy metal type. I put an MFJ 30' multi segment pole into the jaws of the work bench with a 4 element 2mtr beam at the top. Turned the antenna to the direction I wanted and just tightened the jaws of the work bench a bit to hold the pole in place. By just loosening the jaws a bit, it was easy to spin the pole around to search for stations.
Neutrino222
Thanks. I don't suppose you have a picture?
Neutrino222
Us "Old Time" amateur radio operators used our wives (or significant other). Send 'em out to turn the pole until signal strength peaks. Provide rain gear as necessary. c(;<)>.
Cheers. I find that recently I'm not able to place my pole in wet regions any more, hence why I've taken up radio spectrum analysis. ;-)
a417
My loop antenna sat on a lazy suzan for a while. I suppose if you sat a bench vise on top of that it could hold a small aerial.
