antenna up grade
kc2lnb
pomona ,NJ
I have this kg-uv3d and would like to know what antenna i can get for it not sure of the # I think it's sm-77 it is a long antenna , thank you .KC2LNB
W2NJS
Washington DC
The dualband antenna that is furnished with the Wouxun radios is a good unit. I use one on my APX7000 and it performs well. Who is the manufacturer of the "sm-77" unit you mention?
LtDoc
Oklahoma
No idea what the difference is but the supplied antenna with the 'UV-6' is better than the one supplied with earlier/different models. Also, Comet makes a 1/4 wave antenna for the SMA equipped HTs. there's definitely a difference between that one and the supplied Wouxun antennas. Since Comet's antenna is longer it is also not as 'convenient' as a shorter antenna. Works for me, but your milage may vary.
- 'Doc
(No measurements of how well any of them work except by using my 'ears'. Don't expect 'numbers'.)
