Antenna
W
W4ZMJ
Guest
Depends i think vhf uhf antenna are inside of it the 800 antenna on top works well you in a fringe area a motorola half wave antenna will inprove it some
Sent from my LG-H343 using Tapatalk
picscan
CA
I use a Motorola antenna on mine when I want to reach out, from zero bars to 4, it picks up sites that I cannot get with the blue one. One in particular is 17 miles away cannot be heard with the stock antenna in my little neighborhood pocket unless I go out into the street instead of my family room and with the discone on the roof it's even better.
W
W4ZMJ
Guest
The blue antenna compared to a Motorola quarter wave stubby antenna are about equal
N6ML
In my observation, the blue antenna improved an 850MHz signal by about 4dB over the purple one, but at 760MHz, it made no discernible difference.
W
W4ZMJ
Guest
But for convenience the little stub antenna with the blue band is ideal for most of my needs
APX8000
Sarcastic Member
AES-256 secured
Yep, I get the same results with my G5 and the blue antenna next to an APX with the 7/800 stubby.
LEH
Yorktown, Virginia
I have tried a couple of different stubby antenna and I have gone back to the Unication antenna that it came with. Sorry somehow the color ring has vanished or I'd tell you which I have.
kc5igh
Velarde, New Mexico
I've heard reports from people who say they've experienced much better results from the "blue" antenna in the vicinity of 850 MHz and little or no difference between the two at 760 MHz.
I thought I'd buy one of the "blue" antennas to see if it made any difference monitoring a 700 MHz system with 769.XXXX control channel frequencies.
If anything, it seems that the original "purple" antenna that came with my G5 was generally one signal-strength bar ahead of the "blue" antenna. This was an unscientific test I conducted by reading the G5's signal strength meter at a couple of locations. In view of this unscientific test, the "purple" antenna is back on the G5.
I'm not trying to monitor any 800 MHz systems here, but I'll keep the "blue" antenna if I find myself trying to do so in the future.
Thanks for listening!
-Johnnie
N6ML
That was me, in comment #10 ;)
You can get a "real-time" dBm reading by going to the Information page, from the main menu, then the following sequence (it takes a bit of practice to get it right):
* Click joystick thingy
* 224132 (red, red, white, blue, yellow, red)
* Click joystick thingy again
Just be careful to get the sequence right - there's another one that initiates self-destruct....
P.S. I'm kidding about the self-destruct part :p
kc5igh
Velarde, New Mexico
Thanks, N6ML! Yes, I read your post, too.
A couple of my friends tried the same experiment and got the same results. I don't know why I thought my results would be any different, but I love comparing antennas, and it wasn't a very expensive experiment.
How did you come across that dBm sequence? I may give it a try some day.
Also, thanks again for your help programming my G5. It's been a terrific receiver for the 406-420 Mhz digital system I monitor, and I plan to demo it to management to see if they're interested in using it as a pager.
kc5igh
Velarde, New Mexico
My again, N6ML . . . I forgot to ask you yesterday if you'd noticed (as I "think" I did) that the "purple" antenna was slightly more sensitive to 760 MHz signals than the "blue" antenna? It would seem to make sense that it might if the "blue" antenna was tuned to center more narrowly around 850 MHz, instead of spreading itself between 763 and 870 MHz.
Just curious . . . thanks!
-Johnnie
