Issues with programming p25 system
jrock71984
I have attempted to program the Connecticut land mobile radio network multiple times into my unication g5 the specific sites I have programmed into the g5 are the Bridgeport Simulcast and the Troop G simulcast according to radio reference where I live the g5 should be picking up both simulcasts as I live well within the range of both of them. I programmed them the same way as I did with other p25 systems I have programmed on the g5 Using Rdio Reference to Import them. both sites are saying out of range once I program it to my g5 My question is are these sites down or is the information on radio reference wrong that is being imported over to the programming software for the g5 as this is the only system that is giving me this issues.
llzel
St Louis, MO
are you getting out of range? If not only enter one site for the system. It might be affiliating on a site without traffic
jrock71984
yes I am getting out of range according to the map I should not be as I am right in the brewster/Danbury area shown on the mapmap.jpg
jrock71984
Assuming you are in range, do you have all the control channels programmed in? Are you sure the TGs aren't encrypted?
Trp G is working fine
no encrypted talk groups were added when i programed the system below are the maps of both systems I am in the Brewster/Danbury area you can see from the maps I am well within the range of both
Well RR is correct and the sites are up, you can hear them on the calls platform, you might try another site and see what happens
jrock71984
I programmed the sites separately when one did not work i removed it and programed the other site in
jrock71984
tried both bridgeport and troop g sites separately and had the same results this is the only p25 system i have had issues with once programed
jtwalker
BEE00.1E8-1.22 (or) BEE00.689-1.13
I’d say it is one of the following. Eliminate each to the best of your abilities:
1) the info used to program is incorrect.
2) the info used to program has changed since published.
3) mistakes were made programming.
4) pager is out of range of transmitters.
5) pager/antenna is defective.
jrock71984
Well i can rule out number 5 as i can here the putnam county p25 system perfectly I don't know if i can rule out number 1,2 or 3 as I am getting the information directly from radio reference and that might have changed without radio reference updating it. according to the maps on radio reference number 4 could be ruled out as i am well within range
jrock71984
make sure WACN and SYS Id are correct
everything that was programed for this system was imported form radio reference all my other p25 systems on the pager work and were imported in the same way so would that be something incorrect on the rr website that is being carried over to the programing software?
BenScan
D/FW
I would enter the wildcard "FFFF" for the WACN, System, RFSS, and Site IDs. I'd also remove all of the frequencies except for the two sites you are interested in. You may also need to add the frequencies that are listed in black in the RRDB if only the red ones were imported. See if you have any luck with that, and go from there.
blackbelter
Programimg and or importing all the control channels would defintly help.
jrock71984
I only had one site programmed in the g5 when it did not work I deleted the system site off the g5 and programmed the other site with no luck I also made sure all frequencies for the sites were programmed into the g5
