Antennas and Parking Garages
How do police, fire and ambulances deal with parking garages, say you have a quarter-wave VHF antenna mounted on the roof of a cruiser, fire truck, or an ambulance, how do they get into the garage with antenna on the roof that makes it higher than the maximum allowable height for a garage?
tweiss3
Is it time for Coffee?
Ohio
Spring bases. My VHF hits in downtown parking lots all the time.
The antennas are not made out of glass. They do not break when they hit a parking garage.
The whips are very thin and very flexible. They will not have an issue with a parking garage unless there is a stupidly low level of clearance, and that minimal clearance would damage the lights long before it hurt the antenna.
I've had NMO mounts on all my personal vehicles and work vehicles for decades now. My wife's truck has a 1/4 wave whip and she drives it in/out of the garage every day without issue. The top half of the antenna hits the garage door every single time. Been doing that for years. Her old SUV did the same thing, for 10 years. Thousands of passes through the garage without any issues.
And if the clearance was too low, the antenna just flexes back. Worst case is the whip takes a bit of a permanent tilt, but being that we have opposable thumbs, we can easily bend that back to vertical.
Here's a worst case scenario:
My F-350 (aluminum body) with a Larsen NMOQ wide band VHF antenna on the top. These whips are very thick and stiff. There's a spring at the base. I pull into a parking garage and the antenna taps along the overhead. Suddenly the clearance drops to about 4" above the cab. The antenna gets bent all the way back at the spring to 90º. I stop, remove the antenna.
The spring has a permanent list to the stern, but the NMO mount is fine and the whip is fine. Out of the garage I screw it back and and drive home. I ordered a new spring and replaced it, keeping the same NMO mount, base and whip. Everything was fine.
Work truck as a couple of antennas on the roof and gets to play on overgrown site access roads with lots of low tree branches. One of the low tree branches bent the headache rack behind the cab, 2" x 1" steel. Had to remove it, but the antennas on the roof were fine.
Parking garages and low branches are not an issue unless the vehicle operator gets a case of the stupids and drives into a place they shouldn't be.
GadgetGeek
Bergen County, NJ
I just scrape through drive-thrus with my Sirio 5000 antenna. If I have to go into a parking garage I remove the whip. I hit a lot of tree branches too and at work pigeons regularly fly into the whip. :D
rgchristy
Delco, PA
Most fire trucks and ambulances will not fit into a parking garage due to their height, regardless of an antenna.
Emergency rooms have separate loading bays that allow for these types of vehicles that are away from parking garages. Most police vehicles park in these areas, too, since they transport patients.
Maintenance and repair vehicles usually have the same arrangement, but in service/contractor parking areas and shops.
slowmover
Fort Worth
SS HUSTLER or brass BREEDLOVE “Quick Disconnect” are each nice to own given a tall 3/8-24 stud mount.
Depending on which model S-5000 that whip may not be long enough over time.
My base-load PRESIDENT Texas 1800 has a two-piece xtra-long whip that’ll take 100-MPH strikes (company video). In the meantime I drive to avoid strikes.
The Breedlove used as a layover is nice.
The spring-action Hustler is fast to remove the antenna.
NMO, just add the optional spring.
