Antenna's
Is it better to have antenna as close as possible to cb, or far away?...thnxs
Are you referring to coaxial cable length?
All coaxial cable has loss, just different amounts depending on the size, length and frequencies used. Keeping coaxial cable short gets more signal to/from the antenna (works both for transmitting AND receiving), so shorter cable lengths are better.
However, at 27MHz, the difference between, say, 20 and 30 feet is negligible.
Placing the antenna up high and with a good groundplane would outweigh saving a few feet of cable.
