ClemsonSCJ
- Joined
- May 29, 2018
- Messages
- 227
Sorry guys but I feel like I have a question for each face of my shack setup. I’m down to buying the last few things I need (wife’s wanting to save up for a kitchen remodel so I’m having to do the Johnny Cash “one piece at a time” method). Next item on the list is the tripod to mount the antenna. I’ve been primarily looking at the Rohn 5ft cause I plan to use a 10ft fence top rail as my mast, and eventually maybe add another one in the future to make it a 20 footer (guyed of course). With shipping it’ll be right around $100ish. I don’t mind spending that much, and the Rohn seems to be a pretty well respected brand, but I can’t find any specs listed about this things as far as what they’re rated for. Granting I know there’s no way for them to have “weight limits” cause that’s going to vary with mast length, antenna weight, surface area (wind), and endless combinations of those 3 things. But the antenna I’m going to be using for now is just a DBJ-1 so the weight of a 5ft stick of 3/4” PVC is all I got at the top of this 10ft fence rail. So wind drag will be pretty minimal. Also, rather than having the tripod support my mast 100% by itself, I plan to use something like this ( Heavy Duty Roof Mount for Masts up to 1-1/2" OD - EZ 19 Antenna Mast Peak Mount https://www.amazon.com/dp/B012X8PPA...abc_G29MQPGD6RBRN825K3D6?_encoding=UTF8&psc=1 ) to attach the bottom of the mast to the apex of the roof. This should assist with taking a lot of the leverage/torque off the tripod itself.
So all that taken into consideration, my options are a Rohn 5ft tripod at $90, a Rohn 3ft at $70, or an EasyUp 5ft at $50. Again, I’m not trying to be cheap so if I need to go with the Rohn 5ft that’s what I’ll do. But if anyone has had any experience with the EasyUp and can’t tell me a significant different between that and the Rohn, then a $40 savings would be awesome.
