tadpole207
- Joined
- Mar 18, 2022
- Messages
- 105
There is a setting in Chirp that allows connection between Radio Reference and Chirp. I am well aware that one did not develop the other, but there has to be some idea on this issue- i found it on a radio reference forum specifically here: Issue with Chirp | Query data source -> RadioReference
my posst earlier that closed without being able to ask an update since there is no other assistance on Chirp once you run the python- which i did with a a correct install. After the install, i still could not access the radio reference data into Chirp- all Chirp says is to install Python, which i did.
So install via terminal and get
Last login: Wed Mar 30 18:07:57 on ttys000
myname@name-MBP ~ % sudo easy_install -z suds
Password:
Searching for suds
Reading Links for suds
Downloading https://files.pythonhosted.org/pack...66da7a3d5ab163fb5a06b018bbd940a144e00413624ad
Best match: suds 1.0.0
Processing suds-1.0.0.tar.gz
Writing /tmp/easy_install-shu4n5/suds-1.0.0/setup.cfg
Running suds-1.0.0/setup.py -q bdist_egg --dist-dir /tmp/easy_install-shu4n5/suds-1.0.0/egg-dist-tmp-i3V3KB
zip_safe flag not set; analyzing archive contents...
Copying suds_community-1.0.0-py2.7.egg to /Library/Python/2.7/site-packages
Adding suds-community 1.0.0 to easy-install.pth file
Installed /Library/Python/2.7/site-packages/suds_community-1.0.0-py2.7.egg
Skipping dependencies for suds-community 1.0.0
myname@name-MBP ~ %
____________________________________________________________________________________________________________________________________________________
So its installed but when i try to go back, i am in a loop. any thoughts?- did anyone else have this issue and did anything work to stop the loop and allow you to download the radio reference data? I have followed the directions https://chirp.danplanet.com/projects/chirp/wiki/How_to_report_issues. and looked all around the faq and only got the python install message- which i completed successfully. Has anyone else had this problem?
Just wondering if anyone has a solution that worked for them. Please dont kill the post.
thanks
Password:
Searching for suds
myname@name-MBP ~ %
thanks
307.2 KBViews: 4 -
503.8 KBViews: 4
