Any iOS or Android app for nodes?
IAmSixNine
Dallas, TX
Hello group. I was curious if any apps (iOS or Android) that pull audio from the nodes feeds? I know there are a handful of apps for the legacy feeds but with more agencies switching to P25 trunking and nodes getting more feeds I find my self using that more and the standard feeds less. But I have not seen any way to monitor them other then book marking them and using chrome to listen.
Thanks in advance.
Kingscup
As AB5ID stated, Scanner Radio pulls from the Calls but AFAIK, it only pulls from the public playlists available from here. It does not pull from individual nodes. I believe you can make your own public playlists and it will eventually populate to Scanner Radio. More info here.
IAmSixNine
Dallas, TX
Perfect. Thank you @AB5ID and @Kingscup I do have Scanner Radio but its the Pro version which according to that thread is no longer supported and I have downloaded the regular version and started creating play lists .
AB5ID
Lee's Summit, MO (Kansas City)
If you have a premium membership and you log in with your RR credentials on Scanner Radio, you will have access to listen to your personalized Calls playlist.
