Since most scanner antennas these days tend to be tri-band, you have a wider selection since you just want V/U coverage. You can choose from various business band HT antennas and the better VHF scanner antennas.
The Remtronix 842b is a carbon copy of the original "rubber duck" antenna that all handheld scanners came with before Uniden decided that injection-molded paper clips were a better stock antenna. That's will give you as good of VHF performance as anything else of that length.
Retevis has a good dual-band antenna for HTs, but it's definitely an armpit tickler worn on the waist. 😎
