This has been around since RG59 was first developed... it is 75 ohm cable, so all you need to connect it to the input of your receiver is a TV 300 ohm to 75ohm adaptor...
Depending upon how much room you have INDOORS, take a 25 foot chunk of RG59 TV coax. Determine how much distance you will need from the radio to the ceiling. Lets use 7 feet for that as an example... Measure out 7 feet from one end of the coax and strip off the outer covering the rest of the way - 18 feet in this case. Then, remove the BRAID that is exposed, along the same 18 foot length. Leave the white inner insullator intact over the center conductor. Place a small piece of electrical tape over the area where the 7 foot undisturbed run meets the area where the center insullator is exposed - just to cover the raw ends of the braid. Install an 'F' connector at the end of the 7 foot run and a 300 to 75 matcher. Attach one of the twin lead pigtails to the antenna input on your receiver and the other pigtail to the ground termainal. The coax white center insullator should be run as much north and south as you can make it and can be attached to the ceiling using bulletin board pins. If this will be used in an attic, the same applies. This antenna is not recommended for outdoor use because of grounding/lightning issues that you may not wish to get involved in. This is a quick and temporary INDOOR antenna which will give good performance compared to a sectioned pull out antenna which may come with some receivers. I have used this type periodically for nearly 40 years and they do a good job.
