Just installed a Wilson 1000 roof mount antenna on my SUV. The antenna is mounted through a hole in the center of the roof. It is paired with a Uniden PC68LTX CB radio.
After installing the antenna, I attempted to tune it, but found that the SWR is above 3 on all channels no matter how I adjust it. (I am using an external SWR meter.)
I ohmed the jumper coax and the coax cable leading to the antenna, they both have continuity. The antenna mount has .5 ohms of resistance to ground, which shouldn’t be an issue from my understanding.
Where should I go next? The cables appear to be good, along with the ground. I’m pretty sure the SWR meter is good since I used it for a GMRS radio and it had good SWR.
