Anyone experienced this??
mdsxfire
EDBM
Uxbridge, north of the river Thames
Is this what happens when the battery runs completely dead. Came home this am after an overnight shift and this is what it looked like. Has done it once before like a week ago same thing after an overnight ( wife leaves it on) but it powered on last time this time it wouldn’t even after battery pull
mdsxfire
EDBM
So after about 10 mins or so charging a message popped up saying “battery extremely low charging” then powered on about 5 mins later. So I’m going with the battery was completely dead and that’s what it does when that happens. Fully charged and working great as usual now.
KB8KOJ
Centerville, Ohio
Yes, I've had that happen. The USB charging wouldn't work, even after pulling the battery. I was convinced the battery was toast. Set it in the amplified charger for a few hours.. then it turned on and has been fine for 6 weeks?
kinglou0
You can replicate this by trying to do a reset with the unit turned off. The lights will stay on until you switch the unit on and it starts the bootup process.
I'm suspect that there has to be more to the charging issues that everyone is having. Just doesn't make sense why these units are locking up or acting weird simply because they're being charged.
I tried to charge my G5 last night in the car with a 2A car charger and I got multiple charge error warnings before it locked up. I did a reset and the unit was locked to the last zone/knob position I used even if I switched to a different zone. I might have to start carrying a small screwdriver.
