Anytone Anytone 878 FW 1.14 Encryption
Astrak
Mesa, AZ
Does anyone know what was changed? I see in CPS and on the radio there is no longer an option for normal or engaged in encryption and CPS now allows more than for characters to be entered. I was able to communicate between a Btech radio and the 878 using enhanced encryption and whatever key it generates after entering for digits, now the radios no longer communicate. I tried copying the enhanced key from the Btech CPS into the 878 CPS with no luck.
Astrak
Mesa, AZ
I was under the impression that enhanced encryption in previous firmwares was AES256. I reverted back to FW 1.13 and now can communicate in normal encryption mode but still not in enhanced mode. I'll keep messing around and see what I can come up with.
RayAir
Is it really AES and not just a repeated XOR scheme like TYT 128 bit enhanced privacy which is really only a generated 49 bit key stream to XOR over the plaintext? Same key stream every frame?
Astrak
Mesa, AZ
It very well could be, I'm not sure how I would go about finding out if that is what's really happening.
RayAir
If you have dsdplus, add -v4 to your command line, then make some transmissions with encryption on.
Look to see if dsd displays "Alg=EP" and see if MI's display in the scrolling command line type window.
That should be enough to indicate if it's real encryption.
Forts
Ontario, Canada
Oh.... Also if your key doesn't use the entire keyspace (ie 1234BADF00D kinda thing) you need to pad the key with leading zeros to fill the entire keyspace or it doesn't work with Moto. I presume MotoTRBO cps does this automatically behind the scenes.
kayn1n32008
ØÆSØ
Sector 001
It is legit AES256. I’m using an XiR P8668 /w AES256 and a friend is using the AT-D878. For voice calls it works just fine.
It has issues, it does not encrypt text messages or GPS data. The Anytone does not support RC4 40bit with v1.14
kayn1n32008
ØÆSØ
Sector 001
Oh... Also if your key doesn't use the entire keyspace (ie 1234BADF00D kinda thing) you need to pad the key with leading zeros to fill the entire keyspace or it doesn't work with Moto. I presume MotoTRBO cps does this automatically behind the scenes.
Interesting. As easy as it is to generate a 32 byte hex key on a site like random.org, I can’t imaging why you would not fill the entire key space with random characters. Using leading zeros weakens your TEK.
mancow
N.E. Kansas
Would that really be reliable though? I mean they could spoof the hex designation opcode couldn't they?
Astrak
Mesa, AZ
Using firmware version 1.13, both normal and enhanced encryption DSD does not indicate encryption. Using firmware 1.14 DSD does indicate encryption.
RayAir
I'm surprised. Might have to add a couple as backups instead of buying more Hytera's with AES licenses.
RayAir
Same issue with Hytera too.
Thanks for info.
Forts
Ontario, Canada
Because programmers are sometimes lazy and like to use a key they can remember... and really, even if it has a bunch of leading zeros it's still going to be difficult to crack. But yes, it would be potentially weaker.
Oh, also... FW & CPS 15 just dropped with some bug fixes.
Chris-KH2PM
Northern Harnett Co. NC
M0LMK
Kent, UK
Does the 878 have a method to encrypt the signaling and DMRID similar the Hytera over-the-air encryption? I'm looking at replacing some Hytera radios and really like the way they handle this.
