Anytone anytone at-779uv
Firemandakota87
Sunbury PA
can someone help get my at-779uv to read cause it will not read and there is no power going to it i didnt know if i need power going to it or not
CopperWhopper67
You need to apply 12v power to it via a small battery or power supply. It needs to be powered on to communicate to your computer.
FKimble
Newnan, GA
Only mention of Pl or Ph is show below from cut/paste of manual, seems more like zone/groups than tones.
4.12 VFO Scan and Channel Scan
1. VFO scan: In VFO mode, press microphone key or key to start VFO scan . if the
radio has programm PL1, PH1, ,PL2, PH2, PH2 frequency( in the buttom of channel list), VFO
scan will between PL1-PL2 and PL2-PH2.
2. Channel Scan: In channel mode press microphone key and then press key to start
channel scan. Channel scan setting shall be programmed by PC software
Frank
Firemandakota87
Sunbury PA
Frank
can you give more information plz
FKimble
Newnan, GA
I did a search for the radio model programing. The info pasted was the only thing related to your question. Do some searches on the model and maybe something will turn up. Doesn't sound like it has anything to do with tones. Seems like some kind of scan group to me. Good luck.
Frank
nd5y
Wichita Falls, TX
It's probably two sets of Programmable Low/Programmable High search limits for VFO mode scanning.
