Anytone ANYTONE AT-878UVII PLUS - GMRS Transmit
KF8ZR
Maplewood, Minnesota
When I try to program a GMRS repeater pair using the ANYTONE CPS the transmit frequency gives an error message "out of frequency range.
Yet the 878 Manual set the UHF limits as 450-480MHz. Any ideas
turn on your anytone and go to the Setting menu. Scroll down to freq range. It should show 400-480 . If it doesn't then you need to set it in the test menu when you boot up the radio. The codeplug might be set correct but the radio still needs to be matching. This usually won't let you load the codeplug or enter the frequency if it doesn't match what the radio shows.
