Anytone Anytone uv878v1: No audio after two-tone alert
chilenet
This is with a Anytone uv878 Version 1. Firmware is all up to date.
Alert beeps with "Call End" before audio can pass through. I'd like to turn off the end of the call to give my radio and me some time to Rx? The "Call End" prompt box is turned off in Optional Settings/Display.
I saw this posted in a Unication forum but it's applicable to my radio...
"I figured this out.
My G5 was set to "Auto Reset" and apparently the carrier is dropping just long enough that I needed to set Reset to "Delay N Reset" so the pager wouldn't reset between the tones and the audio.
... Does anyone have any suggestions for my Anytone uv878v1?
Thank you.
chilenet
Have you tried adjusting the "Auto Reset Time" box in the 2-tone section of the CPS?
I did but it's possible I need to try more time. I tried 10 seconds and didn't change things. I'll double or triple it. Thanks for the suggestion. I'll reply with the result.
chilenet
Pretty sure I entered the 10 second delay in the wrong field. I have trouble seeing the Anytone text sometimes. So hopefully this takes care of it. Many thanks!
