Baofeng Anyways to manually unlock BF-FHP8
Kingwood, WV
Hey there I see guys online unlocking extra frequencies with a sequence of numbers I have a 2 to 4-year-old radio that looks just like the UVR five and set up the same way, but I can’t seem to get that factory reset to come up. I have a factory reset inside the menu
nd5y
Wichita Falls, TX
If it's a newer radio that only transmits on the amateur bands this may work depending on how old the radio/firmware is.
https://wiki.radioreference.com/index.php/Baofeng_UV-5R#Amateur_Mode_and_Factory_Mode
If you mean "extra frequencies" outside of 136-174 and 400-520 then I have seen other ways that may or may not work. You can make the microprocessor & display show anything from 1.000 to 999.999 MHz but it won't receive or transmit outside of the frequency ranges the RF chip is designed for.
Kingwood, WV
Yeah I wanna do what these uv5r guys are doing it’s a old radio 5-6 years old
Kingwood, WV
It’s not newer it’s 2018
N9JIG
Sheriff
Moderator
Far NW Valley
I am sure there is a YouTube video on there, maybe look there?
nd5y
Wichita Falls, TX
99.9% of YouTube videos about Baofeng and other CCRs are made by people with almost zero radio or electronics knowledge. I don't know which video the OP is referring to but it was probably just BS.
