AOR 5700D LCD Unevenness
beibeisos1
Hi, I just purchased the 5700D but I quickly noticed the LCD screen unevenness, and the viewing angle is quite limited when looking at the screen downwards. I am wondering if anyone has the same issue here.
AOR-262
Try removing Mail Dial. Behind is hidden small screw to adjust screen brightness.
AOR-262
No screw is holding Main Dial. Some pull force is required to remove Main Dial. Small screw is now visible. Turn screw different directions to adjust screen. To replace Main Dial apply some pressure.
imago01
lyon, FRANCE
Aucune vis ne maintient le cadran principal. Il faut tirer légèrement dessus pour le retirer. Une petite vis est alors visible. Tournez-la dans différents sens pour régler l'écran. Pour remettre le cadran principal en place, appuyez fermement.
Tirer légèrement où fortement , ça ne s'enlève pas sur le mien !
AOR-262
@beibeisos1
@imago01
*Update* Information provided has been incorrect.
Please see correct information below. (PLEASE NOTE if Main Dial is removed, no damage should be caused to device or Main Dial rotary encoder).
Correct information:
Remove Sub Dial (see image below)
Behind dial after removal will show small screw for adjustment.
Use small flat screwdriver to make adjustments
LCD screen has some uneven backlighting and viewing angles when tilted.
Be advised making adjustment will control only light intensity.
kruser
Well Known Member
W St Louis Cnty, MO
It's the same thing : impossible !
It can take quite a bit of effort to pull the knobs off. The hardest part is getting a grip on the knob with your fingers.
A tiny flat blade pocket screwdriver between the knob and radio face can help but you need to protect the parts the screwdrivers is prying on so your radio and knob do not get marred up from the screwdriver.
If you do use a small screwdriver, you need to try and apply even pressure on two sides of the knob so you may need two screwdrivers or something skinny and flat behind two places of the knob so it pulls off straight..
One of the rubber things they sell to help grip lids on glass jars can also help you get a grip with just your fingers.
n2pqq
Do you have a photo of this screw behind knob
beibeisos1
Many thanks, I took off the main encoder and adjusted the screw behind it. It is much better now. So I believe the screw behind the main encoder adjusts the contract of the screen.
bagmouse7
NC, USA
So, are there 2 adjustment screws?
One behind the main dial and one behind the secondary dial, and one is for brightness and one is for contrast?
Thanks!
beibeisos1
Thanks!
I confirm that the screw behind the main dial controls contract, but didn't check the the sub dial.
SigIntel8600
Communications Receiver Nut
Pine Barrens
I have no screw behind the sub dial. The tiny screw hole behind the main dial will adjust the contrast. Just make very small adjustments. My 5700D's display was light on the left side when I received it. Probably from getting bounced around during transit. A small adjustment of the screw behind the main dial and now it is perfect.
