Aprs Help
n3tvv
We have an APRS weather station at our repeater,which was placed there by our former club president using his call
He is now a Silent Key,so the club would like to get this it changed from his call to the club's call ?
I was unable to find help section regarding this,or any kind of email here..
Any help would be greatly appreciated
Eric
N3TVV
AK9R
Staff member
Super Moderator
Central Indiana
There should be a TNC wired between the weather station and the radio. What brand and model is the TNC?
n3tvv
I have no idea what type of equipment he used, wasn't sure if the callsign can be changed here or if we have to do it at the station itself ..
jeepsandradios
East of the Mississippi
You most likely need to do it at the station but without knowing the equipment its hard for us to help. If someone can get pictures or determine the model it will help. If you can give us the current call sign maybe we can see if it tells us online what is used for equipment.
jeepsandradios
Is it KN6CW ?
If so aprs.fi lists the device here -
Device:Microsat: WX3in1 Mini
2 minutes of GTS for you shows this -
Initial setup and configuration
  • Connect: Link the WX3in1 Mini to your computer with a USB cable.
  • Run Configurator: Open the Microsat Configurator application on your PC.
  • Read configuration: Select the option to "Read config" to download the current settings from the device into the application.
  • Modify settings: Adjust the various configuration options, such as filters, callsigns, and rates.
  • Write configuration: Choose "Write config" to upload the new settings from the application to the WX3in1 Mini's internal memory.
n3tvv
Is it KN6CW ?
Yes
KB3KBR
(ಠ_ಠ) (◣_◢) (。◕‿◕。)
Oil City, Venango County, PA
what do you mean "here"? radio reference has nothing to do with your local infrastructure.
vagrant
ker-muhj-uhn
California
“Here” as in remotely using DTMF via RF, versus driving to the repeater site.
