APX 7000XE Scan list will scan but had no audio.
KevinC
Encryption
Super Moderator
I'm everywhere Focker!
If you are not unmuting your band plan is wrong. Plenty of guys around that can do it right for you before you turn your radio into a brick and have to pay one of the said guys to unbrick it.
I agree. I don’t know why it took 20 posts for someone to suggest this.
ElroyJetson
I'd point out that if unauthorized affiliation is such a safety hazard, and if people are going to keep buying surplus radios of eBay, then system owners should demand Motorola to make it easy to do NAS. AFAIK, it's mainly a Motorola issue, as Harris and BK can be set up far easier.
Scanners are going to exist, so people aren't hearing anything they couldn't otherwise. Call it harm reduction.
Perhaps the real issue is it defeats the ability of Motorola to sell you expensive stuff, like advanced system keys, KVLs and KMFs, and monitoring services, to fix a problem they created.
Exactly. Moto could make it EASY to configure any radio in scanner mode, with all capacity to transmit blocked off. They could do it with a special version of the CPS or special firmware or both. In fact I could just imagine them making firmware with a switch in it that when activated by using a special option in CPS, renders the radio permanently incapable of transmitting, to be used when an agency retires radios and sends them to the radio shop for deprogramming prior to disposal at auction. To restore transmit capability, new firmware would have to be loaded. Until then it's a scanner.
ANY of these options would enhance system security for their customers, too.
But, yes, declining to patch a security flaw via a simple low cost method does give you an opportunity to sell a much more expensive lock to the customer. Whether it's the most ethical means or not.
