APX 8000 scan list
Pittsboro IN
Just got my hands on an 8000 for the first time and was asked to add a local PD tac channel from a different zone to the scan list.
I got the user guide and found the page where it says to scroll left or right to ScanL.
I don't see it, my 3 screens only have zone choices, keys set, etc.
Based on this I'm assuming scan was not allowed in the code plug but wanted to make sure I'm not missing something.
GTR8000
NY/NJ Database Guy
BEE00
ScnL must be added to the menu options. Doesn't necessarily mean that scan is not allowed in the codeplug. Even if ScnL is in the menu, that particular scan list must allow operator selected scan list members in order to add/delete channels.
crazyboy
NJ
Is there a side button set to turn on scan? If so press and hold it. The list must be set to operator select.
Pittsboro IN
It's there now, don't know what I did differently with the 2nd radio I picked up.
I was told there is no scan priority between zones. We want to scan a UHF channel in one and a VHF in another (both conventional) with priority on the selected channel, is that possible? My searching here didn't find that.
roguexile
Your best bet is to open the codeplug with cps and set your scanlists, and once in there you can set your priorities for each channel.
UNITYXG
Acworth, GA
Do you want to scan a UHF Channel and a particular VHF channel in the same Scan List?
Under the Scan List Options:
Select your Zone and Channel within that Zone for each channel you want to scan.
Scan List Set-Up
Under "Priority Assignment"
Priority 1 Type - Fixed
Priority Member 1 - [your vhf or uhf channel]
Repeat for Priority 2 like you did for Priority 1
Personality Set-Up
Under your Conventional Personality drop down, if you just have one, you can follow along for this for if you have multiple personalities.
Select your Personality (of your choosing)
Scroll Down to "Features"
Select your Scan list that you just created (see above)
Make sure you have a menu item or a button assigned to "Scan"
Now you can set up two different scan lists for two different personalities, or the same scan list for all personalities, but you will need to set which scan list is tied to which personality you choose. Let me know if you have anymore questions, happy to help.
Pittsboro IN
I don't have access to CPS, it's a federal radio with encryption keys stored on the dark side of the moon.
Thanks for the responses.
After lugging the radio around for a hot afternoon in the DC humidity I see that the '8000' part of the model ID is not the price but weight in grams.
