APX programming MDC
dixie729
Daviess Co., KY
I must be over looking this... But I can not for the life of me, figure out how to enable MDC signaling and or TPS PTT Transmission.
I have found how to set it all up. But I don't see anywhere in the conventional personality where I can enable it to any of the channels.
R20.00.03
Ant9270
The Green Weenie
Make sure you have an MDC signaling system set up under Conventional Systems tab. Then go to the specific personality and enable it under signaling. Make sure you set the mute type to “or” otherwise it won’t yield audio.
nhfdcadet
GCT-1
New Hartford, Ct
Its under conventional system, then you go under your personality in the signaling section under non-Astro and select MDC
