OK....if set the "Squelch" setting to OFF a new transmission does NOT turn on the backlight (yea!!!!) and a key-press will turn on the backlight on for the time set then go off and not come back on w/o my key-press!!!Post #2. My backlight stays off unless I press a key. It’s not a guess, it’s a fact.
It does stay off.....unless I press a key (great!), BUT it comes on with every transmission.....THAT'S THE PROBLEM....I wanted it to STAY OFF unless I Hit a Button....period but it also comes on with a new transmission.Would think something in here. I only have the 200 and can have the light completely off at night. Honestly think the 100 should be able to do the same.
Success.....you all finally helped me understand what I was reading.....never thought about the "Squelch" setting!
Yes....use the top USB port to power....Of course it will not charge but you can charge with the lower USB during the day if needed....I have a question is there anyway to turn the charging led off completely? I like to leave it on my nightstand and the red/ green charge status drives us crazy during the night. Not a fan of just laying the unit down to block it.
Hopefully this will help if I understand your question correctly....It won't charge so there will be no led charging indicator
I'm trying to get away from charging from the radio power source and hopefully spare batter/external chargers will be on sale during prime days
All good now since I found the "Squelch" setting for the battery charging settingsNow making it come on and stay with a push of a button is the challenge. Maybe quick press of power button? Not sure.
THANKS TO ALL!
