APX Reflash?
TFC301
Terrebonne Parish, Louisiana
Hi guys,
I was wanting to know if the APX 7000 radio can be reflashed to add other options like FPP, Encryption and Bluetooth?
Where would I have to bring it to get flashed for those options? The dealer, system programmer?
Thank you in advance!
FFPM571
The Mid South
FPP is not an option that can be ordered by anyone but an authorized federal government agency. Not to say its not available by some programmers who can upgrade the radio that are able to do it outside Motorola's control.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
Hi guys, Where would I have to bring it to get flashed for those options? The dealer, system programmer?
Jeff at Sandy's Communications has been great dealing with people who need things like this. A lot of dealers won't touch personally owned radios or they don't know how to order upgrades for higher end radios.
N4DES
Retired 0598 Czar ÆS Ø
South FL
Not true. I have FPP capable APX's that were ordered direct from my account manager, but they do require the side dongle. Either way a local government entity can order them but you just need to know how to do it. :D
davo51
Planet Earth
I own three (3) APX 7000s in various frequency combinations, I ordered mine from dealer and all have FPP without a dongle, just tap it in, I don't use FPP, because the CPS to program the radio is so much easier, also cannot program trunked systems with FPP,
Bluetooth requires a board, but other items can be flashed and Sandy's is great
TFC301
Does the Q53 FPP require the dongle?
Can the "Enable TDMA" option be flashed in as well?
Can it be flashed through CPS or does it require special programming?
Thank yall very much for the quick responses.
davo51
Planet Earth
I have one radio with Q53 and the others are Q52, none require the dongle. TDMA is a Flash Code option, which CPS will not add to your flashcode, you have to purchase it from someone like Sandy's.
When you start shopping for an APX, the flashcode is everything, if you don't have the Legacy System Key flash, you cannot program trunked systems, you also need the 9600 baud flash, etc....best to read up on what flashes are available and what you will be doing with the APX to make sure you get the right flash, when I am in Florida, I use a lot of P25 HAM repeaters, which require Q806 flash, hope this helps, just do some reading on the APX and you will learn what you need for what you want to do.
