APX XE Top Control Module Ribbon Repair
WSCX355
So unfortunately, I had the ribbon/flex cable break in half on the XE Top Control Module. It's the power/volume knob ribbon right as it hits a 90 degree angle before the connector that connect to the VOCOM board. can't even find replacements for this part but I see a lot of the regular size ones and it appears the ribbons and bits on the underneath are pretty similar. Can this be repaired at all or do I have to buy a whole new complete top.
Thanks for any advice or direction here.
Ryan
ElroyJetson
Flexible circuit repair is possible but it's very expensive and requires a specialist to do it. It'd probably cost as much to get the repair done as it does to buy the replacement assembly.
WSCX355
Does the top Control Module come apart at all? It looks like oyu could take the electronics/ribbon connectors off the normal one which you can get easily for $50.
