APX APX6000XE Bluetooth Issue
Radios_With_Jackson
ÆS Ø
Richmond, VA
I purchased an APX6000XE at dayton and discovered my bluetooth RSM does not work with it. When it's connected to the radio there audio for about a seconed and then it drops and then theres nothing. The TX audio works perfectly. I did some testing and the RSM works fine on my other 6k. The RSM is the Opperations Critical mic. Ive checked in CPS and everything related to bluetooth audio is enabled. Any info would be appriciated.
K2NEC
5F6
Have you tried replacing the Bluetooth module in the radio?
K2NEC
5F6
So its a bad BT board. You'll just need to find one with AES then if you really need it
Radios_With_Jackson
ÆS Ø
Richmond, VA
Would refreshing the radios firmware fix the issue? If I unpair the RSM from the radio and the RSM tries to pair to the radio I get audio out but not TX audio. If that makes sense.
K2NEC
5F6
Unlikely. Sounds like its a bad board
