Anytone Anytone 878 display pi-star info, but no PTT. Time slot wrong.
K0AMY
I have two DMR radios... Radioddity GD-73 works perfectly via my hotspot/pi-star. No issues.
Anytone 878UVII Plus, Firmware v. 3.02n. Does not. This radio worked perfectly via hotspot/pi-star for over a year.... then DMR nothing. Still works on 2 meters/70cm. So, the PTT button does work. On a whim, I added a Group List (never used Group List before) in the Anytone CPS codeplug and the Anytone came to life. So, progress... but......
Facts:
1. Anytone will not key up and be recognized by pi-star. Channel info is the same as the Radioddity... digital, CC1 TS2, 12.5k. Talk Groups assigned to channels, Channels assigned to Zone. Rx/Tx frequency is 446.525 simplex. Radio ID is correct.
2. If I key up on the Radioddity, the Anytone display will light up and I have audio. But nothing via PTT. I cannot disconnect or change TGs on the Anytone.
3. Anytone, while displaying pi-star info brought up by the Radioddity radio, is displaying wrong TS number.
The Radioddity channels are programmed to CC1, TS2 and work correctly.
The Anytone codeplug channels are set to CC1, TS2, but again, the Anytone display shows incorrect TS1 on radio display when receiving Talk Group info via Pi-star. Again, the Anytone CPS codeplug channel info programmed to CC1/TS2, but displays TS1 instead.
I got excited when the Anytone display came to life... progress, but not quite there. The solution is out there.... Greatly appreciate any ideas or suggestions!!
~ AmyR. K0AMY
