APX8000 Keys Locked
Fireboy1475
S. Florida
Is there a setting on the APX software where when you turn the radio on it is essentially locked, none of the buttons work and the keypad, switches and dials are all locked out until you hit the PTT. Once you hit the PTT it opens the radio up and you can change channels and change inputs. Has anyone experienced this? I couldn’t find a systemwide setting that indicates a radio lock out. Also be advised that none of my programmable switches are assigned any type of lock.
Fireboy1475
S. Florida
I was't referring to any encryption keys. I was referring to tactile keys (key pad, switches, other buttons)
SimpleSkye
Northern California
Does it say anything on the screen before the PTT is pressed?
dgower
Long Beach, CA
We have had three APX8000's do that out of the box. Dumped our codeplug into the radio and none of the front panel keys work. Repaired under warranty.
riveter
MD
There is no setting for this in APX CPS.
Appears to be a defect or bug. What firmware version are you running?
