APX APX900 Keyload
Shelby county, Alabama
I have heard the 900 can be software keyloaded, I have CPS, KFDTool software and standard APX programming cable, is it possible to load AES in? Does anyone have instructions to do so? Thanks for any help or info
GTR8000
NY/NJ Database Guy
BEE00
Then you should be able to load an AES key using the KFDTool software and the USB cable. The software needs to be in DLI mode for the 900.
lion2479
Have an XPR-7550e, will my programming cable work for the APX900? I am getting conflicting reports.
N4DES
Retired 0598 Czar ÆS Ø
South FL
Yes you can, but you must have the encryption turned on and the CKR identified in the codeplug first and programmed in the radio.
If you don't you will get an error while trying to keyload.
