APX900 Keyloading
Radio99
NW Chicago Suburbs
For the experts out there...
Bought the adapter cable, plugged it into the KLV 5000 and plugged the OEM APX program cable into the adapter. Changed the KVL to radio USB. The APX 8K was set up for software in the secure settings. KVL tried to load the key but timed out and displayed a Keyload Fail message.
Anyone who can offer some insight? Thanks in advance.
KevinC
32D2T/957.282
Super Moderator
I'm everywhere Focker!
Does your radio have APX AES Software Encryption option?
GTR8000
NY/NJ Database Guy
BEE00
QA06653 AES Software Encryption option only applies to some of the lower tier APX models like the APX 900, not to the 8000. The 8000 cannot be keyloaded using the USB method, you need the proper keyloading cable for that radio and it must be in Hardware Encryption mode to keyload with the KVL. There is no software AES with the 8000, only software ADP.
KE4ZNR
Radio Guru
As GTR said the above is one of your issues. Anytime you use the KVL you have to have it setup as Hardware not Software.
GTR8000
NY/NJ Database Guy
BEE00
If I'm wrong about QA06653 Software AES only being applicable to the APX 900, I'm happy to be corrected, however last I checked all mid-tier and high-tier APX models were hardware-only AES. No MACE = no AES in the rest of the APX lineup.
KE4ZNR
Radio Guru
This is correct with all that I have seen with our APX's.
Only software based ENC is ADP/RC4.
GTR8000
NY/NJ Database Guy
BEE00
Thanks, Marshall, as I thought. Odd that a legit 8000 would show software AES in the flash...hmm.
nikronzo
4.X SloppyCast
This is not true
APX8000 can be keyloaded with the standard programming cable, the only Algos are AES256, DES, and ADP. Using DLI (IP) mode of the free KFDtool and having the correct options turned on in the 8000 plus the correct settings in CPS will allow anyone to keyload via software.
8000 options needed respectively are:
  • QA06653 SW-AES
  • QA07949 DES Software Crypto
  • Q667 Advanced Digital Privacy
GTR8000
NY/NJ Database Guy
BEE00
That's interesting...learn something new every day.
