AR8000 AR8000 - 2VFO Problem
brueger
Ruckersville, VA
Hi All,
I want to use my good old AR8000 to stream my local fire/EMS. I'm having trouble getting the scanner to remember the frequency that I've placed in the 2FVO memory. I know how to put the freq in and monitor, but the scanner will not remember the freq if the scanner is powered off. I've scoured the manual, but I can't find the answer to this problem. I know this works cause I used it for streaming before.
Brian Rueger
DudleyG
Lexington, Ky
Not sure how you are powering the AR8000, however whether it is with only batteries or thru the wall wart, you HAVE TO TURN the receiver off using the knob on top of the receiver. If it is powered only by the wall wart (with no batteries in the receiver) and you unplug the wall wart or turn off a power strip to the wall wart, the last changes to the VFO memories are not saved. Likewise pulling the batteries out without turning the receiver off with the top knob will cause the last changes to VFO to not be saved.
AOR-262
@brueger
Yes, brand new keypad for AOR 8000 (AR8000) still available to buy direct from AOR Japan. Link below ...
RichardKramer
Reading, PA
Also, if you have the step size wrong after programming a freq into the vfo and turn the AR8000 off while it is still plugged in or on batteries; the freq you programmed in will change to the closest step size that was set when you turn the scanner back on. As an example if you had 453.1 programmed into the vfo with the step size set to 25kHz, and you enter 453.1375 and you turn the scanner off without changing the step size to 12.5kHz; when you turn the scanner back on the freq in the vfo will revert back to 453.125. I have 2 - AR8000's; one to scan UHF milair freqs in, the other searches the satcom bands or I manually tune through the satcom band with open squelch in the USB mode which makes it easier to hear the data signals. Do you guys have full coverage (old cell band), and the single inversion descrambler chip? Our local hospital uses #3 on the descrambler chip for info on patients coming out of the emerg. room. There are a couple of businesses that use that type of encryption also. I have my two since 1995.
DudleyG
Lexington, Ky
I never had my AR8000 "reprogrammed" or "upgraded" :) to open up the old cell phone band. For several years, I used to go to the Dayton Ham Festival and there was a fellow there that would reprogram it for you as long as you promised you weren't a federal agent, but I never had him perform his magic because at the time I had an ICOM R1 which was not blocked from the old cell phone range and just listened on that. Besides, it was a whole lot more fun to listen to the cordless phones that were deployed throughout my neighborhood in the 1990s on the AR8000. It was sensitive enough to give me 4 or 5 house range around my house.:) Also my AR8000 doesn't have the inversion descrambler chip.
brueger
Ruckersville, VA
@brueger
Yes, a brand new keypad for AOR 8000 (AR8000) is still available to buy direct from AOR Japan. Link below ...
Unfortunately, it's out of stock.
brueger
Ruckersville, VA
Thanks, Richard, I noticed that happens but the agency comes in fine. I will have to go back to the manual and see how to change the step size in the 2VFO mode.
AOR-262
@DudleyG
If you have CR8232 Unit or somebody has this, you can easy reprogram AR8000 US Bandplan. Otherwise, make Programming Socket for AR8000 (see video link below). Then follow list below to add Cellular frequency range.
US Bandplan Table shipped with later US AR8000 (S/N 209xx 5/95) and is comprised of 108 entries. These are listed below. This more recent table maps the AM Band correctly, among other things. The table below show you the entry offset, the EEPROM address, the 16 byte entry, followed by a semicolon and an annotation of the entry's contents.
### Addr Unused +/MD Step Frequency Frequency Step + MDn
0:%7800# FFFFFFFFFFFF 05 00 050000 0000100000 ;0000.100000MHz 000050Hz CW
1:%7810# FFFFFFFFFFFF 02 00 001000 0000530000 ;0000.530000MHz 010000Hz AM
2:%7820# FFFFFFFFFFFF 05 00 050000 0000800100 ;0001.800000MHz 000050Hz CW
3:%7830# FFFFFFFFFFFF 04 00 050000 0000840100 ;0001.840000MHz 000050Hz LSB
4:%7840# FFFFFFFFFFFF 03 00 050000 0000000200 ;0002.000000MHz 000050Hz USB
5:%7850# FFFFFFFFFFFF 02 00 000100 0000500200 ;0002.500000MHz 001000Hz AM
6:%7860# FFFFFFFFFFFF 03 00 050000 0000550200 ;0002.550000MHz 000050Hz USB
7:%7870# FFFFFFFFFFFF 05 00 050000 0000500300 ;0003.500000MHz 000050Hz CW
8:%7880# FFFFFFFFFFFF 04 00 050000 0050720300 ;0003.725000MHz 000050Hz LSB
9:%7890# FFFFFFFFFFFF 03 00 050000 0000000400 ;0004.000000MHz 000050Hz USB
10:%78A0# FFFFFFFFFFFF 05 00 050000 0000200400 ;0004.200000MHz 000050Hz CW
11:%78B0# FFFFFFFFFFFF 03 00 050000 0000360400 ;0004.360000MHz 000050Hz USB
12:%78C0# FFFFFFFFFFFF 02 00 000100 0000000500 ;0005.000000MHz 001000Hz AM
13:%78D0# FFFFFFFFFFFF 03 00 050000 0010010500 ;0005.011000MHz 000050Hz USB
14:%78E0# FFFFFFFFFFFF 02 00 000100 0000890500 ;0005.890000MHz 001000Hz AM
15:%78F0# FFFFFFFFFFFF 03 00 050000 0050210600 ;0006.215000MHz 000050Hz USB
16:%7900# FFFFFFFFFFFF 05 00 050000 0000330600 ;0006.330000MHz 000050Hz CW
17:%7910# FFFFFFFFFFFF 03 00 050000 0000500600 ;0006.500000MHz 000050Hz USB
18:%7920# FFFFFFFFFFFF 05 00 050000 0000000700 ;0007.000000MHz 000050Hz CW
19:%7930# FFFFFFFFFFFF 04 00 050000 0000150700 ;0007.150000MHz 000050Hz LSB
20:%7940# FFFFFFFFFFFF 02 00 000100 0000300700 ;0007.300000MHz 001000Hz AM
21:%7950# FFFFFFFFFFFF 03 00 050000 0000550700 ;0007.550000MHz 000050Hz USB
22:%7960# FFFFFFFFFFFF 05 00 050000 0000360800 ;0008.360000MHz 000050Hz CW
23:%7970# FFFFFFFFFFFF 03 00 050000 0080710800 ;0008.718000MHz 000050Hz USB
24:%7980# FFFFFFFFFFFF 02 00 000100 0000400900 ;0009.400000MHz 001000Hz AM
25:%7990# FFFFFFFFFFFF 05 00 050000 0000101000 ;0010.100000MHz 000050Hz CW
26:%79A0# FFFFFFFFFFFF 03 00 050000 0000151000 ;0010.150000MHz 000050Hz USB
27:%79B0# FFFFFFFFFFFF 02 00 000100 0000551100 ;0011.550000MHz 001000Hz AM
28:%79C0# FFFFFFFFFFFF 03 00 050000 0000071200 ;0012.070000MHz 000050Hz USB
29:%79D0# FFFFFFFFFFFF 05 00 050000 0000601200 ;0012.600000MHz 000050Hz CW
30:%79E0# FFFFFFFFFFFF 03 00 050000 0000101300 ;0013.100000MHz 000050Hz USB
31:%79F0# FFFFFFFFFFFF 02 00 000100 0000601300 ;0013.600000MHz 001000Hz AM
32:%7A00# FFFFFFFFFFFF 05 00 050000 0000001400 ;0014.000000MHz 000050Hz CW
33:%7A10# FFFFFFFFFFFF 03 00 050000 0000101400 ;0014.100000MHz 000050Hz USB
34:%7A20# FFFFFFFFFFFF 02 00 000100 0000001500 ;0015.000000MHz 001000Hz AM
35:%7A30# FFFFFFFFFFFF 03 00 050000 0000701500 ;0015.700000MHz 000050Hz USB
36:%7A40# FFFFFFFFFFFF 05 00 050000 0000001600 ;0016.000000MHz 000050Hz CW
37:%7A50# FFFFFFFFFFFF 02 00 000100 0000501700 ;0017.500000MHz 001000Hz AM
38:%7A60# FFFFFFFFFFFF 05 00 050000 0000001800 ;0018.000000MHz 000050Hz CW
39:%7A70# FFFFFFFFFFFF 03 00 050000 0000111800 ;0018.110000MHz 000050Hz USB
40:%7A80# FFFFFFFFFFFF 05 00 050000 0000002100 ;0021.000000MHz 000050Hz CW
41:%7A90# FFFFFFFFFFFF 03 00 050000 0000202100 ;0021.200000MHz 000050Hz USB
42:%7AA0# FFFFFFFFFFFF 02 00 000100 0000452100 ;0021.450000MHz 001000Hz AM
43:%7AB0# FFFFFFFFFFFF 03 00 050000 0000812100 ;0021.810000MHz 000050Hz USB
44:%7AC0# FFFFFFFFFFFF 05 00 050000 0000892400 ;0024.890000MHz 000050Hz CW
45:%7AD0# FFFFFFFFFFFF 03 00 050000 0000932400 ;0024.930000MHz 000050Hz USB
46:%7AE0# FFFFFFFFFFFF 02 00 000100 0050512600 ;0026.515000MHz 001000Hz AM
47:%7AF0# FFFFFFFFFFFF 05 00 050000 0000002800 ;0028.000000MHz 000050Hz CW
48:%7B00# FFFFFFFFFFFF 03 00 050000 0000202800 ;0028.200000MHz 000050Hz USB
49:%7B10# FFFFFFFFFFFF 01 00 001000 0000602900 ;0029.600000MHz 010000Hz NFM
50:%7B20# FFFFFFFFFFFF 01 00 001000 0000003000 ;0030.000000MHz 010000Hz NFM
51:%7B30# FFFFFFFFFFFF 01 00 000500 0000454600 ;0046.450000MHz 005000Hz NFM
52:%7B40# FFFFFFFFFFFF 01 00 000500 0000504900 ;0049.500000MHz 005000Hz NFM
53:%7B50# FFFFFFFFFFFF 05 00 050000 0000005000 ;0050.000000MHz 000050Hz CW
54:%7B60# FFFFFFFFFFFF 03 00 050000 0000105000 ;0050.100000MHz 000050Hz USB
55:%7B70# FFFFFFFFFFFF 01 00 000500 0000415100 ;0051.410000MHz 005000Hz NFM
56:%7B80# FFFFFFFFFFFF 00 00 002500 0000005400 ;0054.000000MHz 025000Hz WFM
57:%7B90# FFFFFFFFFFFF 01 00 002000 0000006600 ;0066.000000MHz 020000Hz NFM
58:%7BA0# FFFFFFFFFFFF 01 00 000100 0000007300 ;0073.000000MHz 001000Hz NFM
59:%7BB0# FFFFFFFFFFFF 02 00 000500 0000607400 ;0074.600000MHz 005000Hz AM
60:%7BC0# FFFFFFFFFFFF 00 00 002500 0000007600 ;0076.000000MHz 025000Hz WFM
61:%7BD0# FFFFFFFFFFFF 00 00 000001 0000008200 ;0082.000000MHz 100000Hz WFM
62:%7BE0# FFFFFFFFFFFF 02 00 005000 0000000801 ;0108.000000MHz 050000Hz AM
63:%7BF0# FFFFFFFFFFFF 02 00 002500 0000001801 ;0118.000000MHz 025000Hz AM
64:%7C00# FFFFFFFFFFFF 01 00 000100 0000503501 ;0135.500000MHz 001000Hz NFM
65:%7C10# FFFFFFFFFFFF 01 00 501200 0000003801 ;0138.000000MHz 012500Hz NFM
66:%7C20# FFFFFFFFFFFF 05 00 050000 0000004401 ;0144.000000MHz 000050Hz CW
67:%7C30# FFFFFFFFFFFF 03 00 050000 0000104401 ;0144.100000MHz 000050Hz USB
68:%7C40# FFFFFFFFFFFF 01 00 000500 0000604401 ;0144.600000MHz 005000Hz NFM
69:%7C50# FFFFFFFFFFFF 03 00 050000 0000804501 ;0145.800000MHz 000050Hz USB
70:%7C60# FFFFFFFFFFFF 01 00 501200 0000004601 ;0146.000000MHz 012500Hz NFM
71:%7C70# FFFFFFFFFFFF 01 00 000100 0000004801 ;0148.000000MHz 001000Hz NFM
72:%7C80# FFFFFFFFFFFF 01 00 000500 0000005101 ;0151.000000MHz 005000Hz NFM
73:%7C90# FFFFFFFFFFFF 01 00 501200 0000256301 ;0163.250000MHz 012500Hz NFM
74:%7CA0# FFFFFFFFFFFF 00 00 002500 0000007401 ;0174.000000MHz 025000Hz WFM
75:%7CB0# FFFFFFFFFFFF 01 00 002000 0000001602 ;0216.000000MHz 020000Hz NFM
76:%7CC0# FFFFFFFFFFFF 01 00 000100 0000002202 ;0222.000000MHz 001000Hz NFM
77:%7CD0# FFFFFFFFFFFF 02 00 002500 0000002502 ;0225.000000MHz 025000Hz AM
78:%7CE0# FFFFFFFFFFFF 01 00 000500 0000000004 ;0400.000000MHz 005000Hz NFM
79:%7CF0# FFFFFFFFFFFF 03 00 050000 0000003004 ;0430.000000MHz 000050Hz USB
80:%7D00# FFFFFFFFFFFF 05 00 050000 0000003204 ;0432.000000MHz 000050Hz CW
81:%7D10# FFFFFFFFFFFF 03 00 050000 0050123204 ;0432.125000MHz 000050Hz USB
82:%7D20# FFFFFFFFFFFF 01 00 501200 0000003304 ;0433.000000MHz 012500Hz NFM
83:%7D30# FFFFFFFFFFFF 03 00 050000 0000003504 ;0435.000000MHz 000050Hz USB
84:%7D40# FFFFFFFFFFFF 01 00 501200 0000003804 ;0438.000000MHz 012500Hz NFM
85:%7D50# FFFFFFFFFFFF 01 00 002500 0000006004 ;0460.000000MHz 025000Hz NFM
86:%7D60# FFFFFFFFFFFF 01 00 501200 0000506104 ;0461.500000MHz 012500Hz NFM
87:%7D70# FFFFFFFFFFFF 01 00 002500 0000006504 ;0465.000000MHz 025000Hz NFM
88:%7D80# FFFFFFFFFFFF 01 00 501200 0000007004 ;0470.000000MHz 012500Hz NFM
89:%7D90# FFFFFFFFFFFF 00 00 002500 0000002005 ;0520.000000MHz 025000Hz WFM
90:%7DA0# FFFFFFFFFFFF 01 00 501200 0000000608 ;0806.000000MHz 012500Hz NFM
91:%7DB0# FFFFFFFFFFFF 01 00 003000 0000002508 ;0825.000000MHz 030000Hz NFM
92:%7DC0# FFFFFFFFFFFF 01 00 501200 0000004908 ;0849.000000MHz 012500Hz NFM
93:%7DD0# FFFFFFFFFFFF 01 00 003000 0000007008 ;0870.000000MHz 030000Hz NFM
94:%7DE0# FFFFFFFFFFFF 01 00 501200 0000009408 ;0894.000000MHz 012500Hz NFM
95:%7DE0# FFFFFFFFFFFF 00 00 501200 0000004012 ;1240.000000MHz 012500Hz WFM
96:%7E00# FFFFFFFFFFFF 01 00 501200 0000007012 ;1270.000000MHz 012500Hz NFM
97:%7E10# FFFFFFFFFFFF 00 00 002500 0000007612 ;1276.000000MHz 025000Hz WFM
98:%7E20# FFFFFFFFFFFF 01 00 002500 0000008212 ;1282.000000MHz 025000Hz NFM
99:%7E30# FFFFFFFFFFFF 03 00 050000 0000509112 ;1291.500000MHz 000050Hz USB
100:%7E40# FFFFFFFFFFFF 05 00 050000 0000009612 ;1296.000000MHz 000050Hz CW
101:%7E50# FFFFFFFFFFFF 03 00 050000 0000159612 ;1296.150000MHz 000050Hz USB
102:%7E60# FFFFFFFFFFFF 05 00 050000 0000809612 ;1296.800000MHz 000050Hz CW
103:%7E70# FFFFFFFFFFFF 01 00 002500 0000009712 ;1297.000000MHz 025000Hz NFM
104:%7E80# FFFFFFFFFFFF 00 00 002500 0000409912 ;1299.400000MHz 025000Hz WFM
105:%7E90# FFFFFFFFFFFF 01 00 000001 0000000013 ;1300.000000MHz 100000Hz NFM
106:%7EA0# FFFFFFFFFFFF 01 00 002500 0000005013 ;1350.000000MHz 025000Hz NFM
107:%7EB0# FFFFFFFFFFFF 01 00 000100 0000000014 ;1400.000000MHz 001000Hz NFM
108:%7EC0# FFFFFFFFFFFF FF FF FFFFFF FFFFFFFFFF
109:%7ED0# FFFFFFFFFFFF FF FF FFFFFF FFFFFFFFFF
110:%7EE0# FFFFFFFFFFFF FF FF FFFFFF FFFFFFFFFF
111:%7EF0# FFFFFFFFFFFF FF FF FFFFFF FFFFFFFFFF
112:%7F00# FFFFFFFFFFFF FF FF FFFFFF FFFFFFFFFF
113:%7F10# FFFFFFFFFFFF FF FF FFFFFF FFFFFFFFFF
114:%7F20# FFFFFFFFFFFF FF FF FFFFFF FFFFFFFFFF
115:%7F30# FFFFFFFFFFFF FF FF FFFFFF FFFFFFFFFF
116:%7F40# FFFFFFFFFFFF FF FF FFFFFF FFFFFFFFFF
117:%7F50# FFFFFFFFFFFF FF FF FFFFFF FFFFFFFFFF
118:%7F60# FFFFFFFFFFFF FF FF FFFFFF FFFFFFFFFF
119:%7F70# FFFFFFFFFFFF FF FF FFFFFF FFFFFFFFFF
120:%7F80# FFFFFFFFFFFF FF FF FFFFFF FFFFFFFFFF
121:%7F90# FFFFFFFFFFFF FF FF FFFFFF FFFFFFFFFF
122:%7FA0# FFFFFFFFFFFF FF FF FFFFFF FFFFFFFFFF
123:%7FB0# FFFFFFFFFFFF FF FF FFFFFF FFFFFFFFFF
124:%7FC0# FFFFFFFFFFFF FF FF FFFFFF FFFFFFFFFF
125:%7FD0# FFFFFFFFFFFF FF FF FFFFFF FFFFFFFFFF
126:%7FE0# FFFFFFFFFFFF FF FF FFFFFF FFFFFFFFFF
127:%7FF0# FFFFFFFFFFFF FF FF FFFFFF FFFFFFFFFF
Programming Video for socket ...
DudleyG
Lexington, Ky
Thanks for the info. I don't know anybody who has a CU8232 and the serial number on mine is 0207xx. I am not good at making and/or modifying electronic so I wouldn't even attempt the second method.
FWIW, I have 3 AR8200MK3 receivers that are unblocked so I can scan just about anything I want to that is analog. I use the AR8000 mostly for VHF Air monitoring. Originally I used it also for police and fire in the old days, but now almost everything near me that is police or fire is digital and most of it is encrypted and what isn't is mostly NXDN and P25.
RichardKramer
Reading, PA
To change the step size in 2vfo mode: In expert/newuser 2ndF mode - press func button -press #2 step button - turn top knob to select size - press ent. IF in expert/newuser func mode, you will have to hold in the func button while pressing the #2 step button.
