ARC XT Question
Junior08
Cape Cod
Testing some web importing using this software, I think I found a bug. Frequencies that use a DPL tone, the tone is not importing into the software. PL tones seem to work fine but DPL's are not. If this has been asked before I apologize. Software bug or database bug?
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
In order to test whether this is a DB issue, we need to know precisely what you were importing- we can then try it with FreeScan and other software...Mike
Junior08
Cape Cod
I tried it with a few Counties in MA. First Barnstable then Plymouth then Norfolk, and the results are conclusive. Any town that uses a DPL, that tone (DPL) is not importing into the ARC software. PL tones are importing fine.
captclint
Mentor
Mountaintop, PA
Confirmed! And I tried a few in PA with same results as in MA. I have XTpro V1.8 build 3.. This must be a recent bug, as I never had that problem with earlier versions.. Hopefully, Gommert from Butel will see this and comment. BTW, FreeSCAN is OK, so it is not a DB issue.
Another recurring bug is the failure to auto load the saved profile. It just started doing this, and not when I upgraded. No, I don't have the virtual control checked. I seemed to recall Gommert recommending deleting the folder "c:/butelsoap" Did that without any improvement. So I just restored it, and now the auto load is working, but it was acting up before I deleted it???.
fxdscon
¯\_(ツ)_/¯
Confirmed here as well.
DPL's are not importing using ARC-XT PRO - V1.8 Build 3.
Also confirming that those same DPL's do import properly when using Free Scan.
captclint
Mentor
Mountaintop, PA
Build 4 released today fixes the DPL issue. Also seems to have fixed the profile auto load, although I have seen this to come and go. Hopefully, it will continue to work.
