ARC15 PRO - data into ARC XT
rvacs
Tulsa, OK
Hello All,
I was hearing that I could take the data from my ARC15 PRO and take it into my new ARC XT for my BCD996xt. I tried Saving and doing an import but the data is not showing up to select.
Has anyone done this - any suggestions?
rvacs
Tulsa, OK
Thanks - One Last Question...
I noticed you mentioned FILE -> BATCH IMPORT.... Is there a FILE -> BATCH EXPORT on the other side? Was always confused why I couldn't just save all the System I have setup... (Is that what a Profile is).
So that when I load up my ARC15 PRO that it starts up with all my systems already loaded instead of me having to open each one....or what I do most of time is just read it back from the scanner.
Basically I want my BCD996XT I just got to be identical in systems etc. as my BCT15.
Thanks Again!!
rvacs
Tulsa, OK
THANKS ....Last quick question....
I know your ARC XT and ARC15 PRO get to radio reference on a particular port....at work this is blocked. But is there a way to put in proxy info to get through to it?
THANKS AGAIN FOR ALL YOUR HELP!!
