arc246... "resouurces not available"
eecame
Vancouver, WA
I was uploading some trunked system and it seems like they uploaded fine but at the end I received an error that said "unable to create channel: resourced not available."
The scanners memory is only 50%. and since all the data came from here and is complete as far as i can tell, i'm a bit stumped.
Butelsoftware
Dayton Hamvention
You are probably trying to program more than 200 talkgroups in a trunk system. The scanner can only store a maximum of 200 talkgroups/system. A workaround it to use 2 systems and assign them the same name and quickkey.
Gommert
www.butelsoftware.com
eecame
Vancouver, WA
I misunderstood, methinks.
Ah, I think you're right. I misunderstood and was thinking that I could have 200 talkgroups per group, not 200 per system. That would explain it since the BOEC has more than 400 talkgroups!
I didn't program them all but I'm pretty sure I have more than 200 in the system.
Thanks for the clarification!
