ARC433 Error Message
DotNM
Watchung, New Jersey
Has anyone seen this message from the ARC for Radioshack PRO433/528 software? I purchased it from here on the RadioReference website and haven't been able to get it to download from RR.
ARC433
FaultCode: SOAP-ENV:Client
FaultString: Operation 'x' is not defined in the WSDL for this service
OK
Is there any way to fix this? I've verified firewall settings and have uninstalled/reinstalled. I have a premium subscription as I'm a feed provider, and I've tried the evaluation copies of other ARC software versions and it works okay in those - the problem is only in the ARC433 version.
RonnieUSA
Rowan County,KY (Morehead)
Did You try downloading it from Butel?
System Requirements:
Windows XP/2000/Vista/7
Radioshack PC interface cable 20-047 or 20-546 or the GRECOM USB cable
IMPORTANT: Radioshack cables 20-048 and 20-049 do NOT work with the Pro-433/528/2051
Use other cables at your own risk! Use the ARC433 demo version to verify communication works before purchasing the software! All software sales are final.
RadioShack PRO-433 PRO-528 PRO433 PRO528 Software
DotNM
I couldn't find a copy of that file anywhere on my system, hidden or not hidden.
I actually found the files and deleted them all then restarted the computer but I have the same problem. I also uninstalled the software, rebooted and reinstalled but am continuing to have the problem.
Here's the info from the faultlog file in the same directory.
06-30-2013/12:35:18
Application: 250
Key:31633123
USer: DotNM
PW:[removed for security]
Version:4
<S:Envelope
xmlns:Enc="http://schemas.xmlsoap.org/soap/encoding/"
xmlns:S="http://schemas.xmlsoap.org/soap/envelope/"
xmlns:XS="http://www.w3.org/2001/XMLSchema"
xmlns:XI="http://www.w3.org/2001/XMLSchema-instance"><S:Body><S:Fault S:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" XI:type="S:Fault"><faultcode XI:type="XS:string">SOAP-ENV:Client</faultcode><faultactor XI:type="XS:string"></faultactor><faultstring XI:type="XS:string">Operation 'x' is not defined in the WSDL for this service</faultstring><detail XI:type="XS:string"></detail></S:Fault></S:Body></S:Envelope>
Butelsoftware
Dayton Hamvention
Try re-installing a new copy. Also doublecheck you entered the correct username/password in the RR import window and make sure that ARC433 is allowed full internet access in your firewall or as a test disable the firewall.
Gommert
Butel Software
