Archive Codeplug Needed for MTS2000
kc8mln
Lancaster, Ohio, USA
I am in need of an archive codeplug for a radio....
Here's the story: a friend of mine gave these radios to me after a radio shop attempted to program them, but the radio shop didn't make a backup copy of the "original" codeplug in the radios before attempting to write them, the result was that they were "bricked" with a Fail 01/82 due to Programming and NOT as a result of an external hardware failure.
So,....I am attempting to find someone with an archive codeplug that matches the exact model #'s of the radios I have, so that I can attempt to push a "good" codeplug into the radios.
The two radios and their info is as follows:
Radio #1:-> MTS2000 w/Flashport B3 -- Model# H01WCD4PW1BN
Radio #2:-> MTS2000 B7 -- Model # H01WCH4PW1BN
I hope to "save" these radios from being "bricks" if I can get a copy of a good ccodeplug for these models. If you can help, please PM me.
~Thanks!
station32
Augusta Me
Sorry for the bad news but from the experience I have that will not work at all due to something called toolproofing which will brick the radio anyway even if you try it. I have tried dumping different codeplugs in to my MTS2000's and bricked them everytime. The ONLY way to bring it back is to Save the S-Record before you start anything. With the S-Record you can bring back your radio every time unless you actually physically damage the radio. If i could help you out with anything else please let me know.
Joe
P.S. The code plug you try to push into it must have the same serial and model number or you run into the toolproofing problem again and even at that I have never gotten a code plug to bring a radio back it needed to be the S-Record.
gatekeep
FAIL 01/93
New York, NY
You *might* be able to clone a good codeplug into the radios to revive them, but you CANNOT and SHOULD NOT directly write the radios with Lab if the radio firmware >R5.42.
station32
Augusta Me
gatekeep i have even tried that with no success but there is a program to untoolproof a radio i have never seen it but word has it its out there.
rescue161
KE4FHH
Hubert, NC
What version is the firmware? If it is below 5.42, then just use lab.
