Are The CDM series of radios DTMF Capable
Radio_Shop
Mesa AZ
So I wanted to know if any of the cdm series of radios decode dtmf tones. we have cdm 1250/cdm1550 and cdm1550ls+ on the shelves and i need to setup a station alarm system for one of our fire stations who get toned out using dtmf. Also they do not recieve tones on their xts5000r's and im not sure why they dont>>? are some of the 5000's not dtmf capable? kind of like only certain ht1250ls+'s are quickcall II compatable?
Sorry for all the dumb questions i started out just being the guy who installed the radios into the ambo's and fire trucks but now im getting sucked into the handheld and programming side of things! :mad:
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Yes, the CDM's will do that.
Can't help with the other series.
Radio_Shop
Mesa AZ
Ok so im a rookie and must be doing something wrong. in the cdm cps. I go to the signaling option of the tree type in my primary ID. then i go to my conv. personality and click on ch 2 thats the channel we transmit dtmf tones on. when i click on the signaling tab of channel 2 I only see the dtmf option in the drop down box of the TX. This radio needs to alarm the crew once it recieives or (decodes) a dtmf tone so wouldn't I need the dtmf option enabled on the RX side?
Sorry for all the rookie questions im sure this is a simple fix and im just a bone head!
davidgcet
the CDM 750 is encode only, the 1250/1550 do encode and decode.
Radio_Shop
Mesa AZ
im working on a 1550ls+ im wondering if this is a model number issue simular to the ht1250ls+'s only having quick-call II on certain model numbers? what do you guys think!
davidgcet
OLDER 1550LS are whole other animals on their options. They don't support DTMF decode only encode, at least according to one of my old price books. Try one of your non LS radios, if the alerting is not done on a LTR group then you can just put in the repeater channel.
Also, there are aftermarket DTMF decode boards available but you will have to be comfortable wiring them in to the radio or accy port.
a417
LS+ (which is actually a feature limited model of the LS, despite the ironic "+" in the name) came in a couple of different model revisions, what's the model # you have? I have seemingly identical models, both LS+ ... and one will do signalling, and one won't...
SteveC0625
Fully agree. I've got three LS+'s in my inventory that are a constant source of headaches because of these limitations (or is it features?)
If the OP would put up the model number of the radio, I (or someone else) can check what it will or won't do in DTMF.
FWIW, using a radio without the LS bells and whistles like the CDM1250 might work better because we know the DTMF is fully functional on both Tx and Rx in that model. I believe a straight CDM1550 will do so as well.
Radio_Shop
Mesa AZ
No luck gents just pulled a 1250 and a 1550 off the shelf read them and once again no option for dtmf-1 under the signaling tab on the specific channel i need tones on. the dtmf option there on the initial tree veiw but not on the channel rx drop down box only on the tx drop down box!!?!?!?!?!? whiskey tango foxtrot!
davidgcet
because the LS/+ series are LTR trunk capable so some "features" were removed.
I just programmed an old 750 portable this morning and the ONLY signaling it supports is MDC. yet a newer revision of the same one supports DTMF and 2 tone as well. It all depends on when the unit was made as to which features it had. When the CDM and CM lines came out you actually had to drop down to the CM line to get many of these options.
Radio_Shop
Mesa AZ
good info thanks. so it basicly comes down to finding out what model number of cdm if any supports recieving dtmf tones
SteveC0625
Further research (google searches) shows that the CDM's need an option board (AAHLN9729C) installed in them to decode DTMF:
Batboard • View topic - CDM1250 - DTMF Rx signalling
Batboard • View topic - CDM1250 Call Alert
Edit to add: AAHLN9729C is $104 from MOL.
2nd Edit to add: There is also AAHHLN4182A DTMF Decode Option Board - Field Install Only (only compatible with CDM1250 & CDM1550) for $82.50
Also needed is RLN4823B Mobile Option Board Installation Kit (required to install Option Boards for $16.50
Radio_Shop
Mesa AZ
were both on the bal I just called moto and found out the same thing so we are ditching the cdm idea and going to the xtl1500. Thanks for all the helpfull input guys!
cabletech
Puget Sound
radio_shop are you REALLY sure that the department is using DTMF?
You do know the differance between DTMF, Quick call and how they work, right?
DTMF is the tones you get when you press a button an any phone and in some radio mics.
Quick Call is a form of tone signaling that works very differant.
I would say that 99.9.3% of ALL fire departments use a form of Quick Call and not DTMF.
