SDS100/SDS200: Are
JASII
Memory Capacity
When the Uniden SDS100 monitors a signal and displays DMR (not CAP/CON/DT3/XPT), does that mean it could be a conventional (not trunked) DMR repeater or simplex on DMR?
If it is DMR simplex, can the Uniden SDS100 differentiate between Time Slot 1 and Time Slot 2?
(I have read that earlier simplex programming didn't use a Time Slot, but some newer radios can use Time Slot 1 or Time Slot 2 on simplex.)
Also, if a frequency being monitored is part of a single-frequency Motorola Capacity Plus system, does the Uniden SDS100 show the Digital Status as DMR or CAP?
(If I recall correctly, it will display it as CAP and then the challenge is to determine which, if any, other frequencies are part of that Capacity Plus system.)
N1XDS
ÆS Ø
Yes the scanner will show either the system is a DMR or Capacity Plus system. If it's a Capacity Plus system then it'll either be 1.2, 3, 4 site system or maybe more all depends on the business or etc.
