arkansas state police help
jimhw1893
I am trying to listen to Arkansas State police Troop C and D but am not having any luck at all
I have programmed in the (red) control channels for these areas even tried them all to no avail
distance is not an issue I am travelling within site of some of the towers ie memphis to paragould
arkansas and memphis to blytheville ark. there is nothing not even a broken signal or static.
I am familiar with programming my 396T and have had good luck with it. but I cannot get it
to do anything with this system.
someone give me some advice on this so I can monitor these areas.
equipment is uniden 396t with the 800 mhz antenna from radioshack, software is ARC
I am just missing something in doing this and cant figure it out.
should I be programming it with the 800mhz or the Apco 25 it dosent make any difference with the
memphis channels.
jimhw1893
Yes I have tried using the Apco25 setup still no activity, I have tried
them all, used all of the talkgroups even made a system with almost
everything in it still not a sound programed it and drove withing a mile
of the Shell Lake tower in crittenden co ark still nothing. I know I am doing
something wrong just can find it.
Someone let me know what control channels they are using for Arkansas Troop C, D
I do have the jonesboro city programmed and it works fine
Just no ASP at all.
jimhw1893
I have tried it both ways with no activity, I will try again tonight
to see if I can get anything, I am doing it the same way I did my
memphis systems, the jonesboro city system but I just get nothing
from the state police, I am in memphis in the downtown area close to
the river and I know I will probably not get them there except for a skip
or something but I am traveling in both the C and D troop area
just dont get it like I said I am just missing something small that is
causing it not to work
If I had a known control channel and a known talk group to test then
I would know it works.
josephdavis13
Austin Texas
Here are the site numbers with control channels for the C and D Troops for you to cross check;
site 153, troop c 866.08750
site 154, troop c 866.23750
site 155, troop c 866.27750
site 157, troop d 866.21250
site 158, troop d 866.72500
site 159, troop d 866.17500
site 160, troop d 866.18750
site 170, troop c 860.98750
site 171, troop c 866.12500
ncentralark
North Central Arkansas
It's interesting to hear your delima; I was traveling in the same area a few weekends ago. Going across 14 from Harrisburg to Marked Tree and then down to Marion-West Memphis. Once I got to Marked Tree I wasn't able to get much. I picked up Burdette for a while but I could not get Shell Lake, or Lake City. In fact I was not able to get the 396 to lock onto the control channel for Shell Lake. I though I might have just locked them out o rhad them entered wrong. Anyway I am going to take a look at my set up. I have a trip this week back to the area and I will try again.
