Army Guard
evilbrad
My head makes a bad antenna
Any interesting guard frequencies in use with the deployments
MarcusDude
Appleton, Wisconsin
Any idea where to even search? Aside from some WISCOM talkgroups, and some site specific frequencies (McCoy. Volk, ect) I don't even know where to search or what band to search in.
KD4YGG
Caveat 1 - These are from the November 2003 issue of Monitoring Times, so they may not even be current, valid or currently utilized.
Caveat 2 - This list is not exhaustive, as situations, equipment, etc. can change at any time.
Nationwide VHF low band common: 38.400 (normal FM)
WI National Guard VHF low band: 40.800, 40.900, 41.600, 46.700 (should be normal FM)
WI National Guard VHF high band: 141.1000
WI National Guard Air band: 123.050, 123.400, 241.000, 299.900
On HF, the following are listed: 4607.0, 5087.0, 8056.0, 8093.0, 13722.0, 14653.0, 20906.0
Automatic Link Establishment (ALE) notes:
Callsign: AB1WI
ALE Address: MWINGB
NGB #: NGB62
As others have stated, don't forget WISCOM talkgroups, Wisconsin Interop Channels, Nationwide Interop Channels, and others.
Don't count out the WISCOM "Site-On-Wheels" that's available for deployment should the need arise.
The article lists the following recommended search ranges:
30.0000-30.5500 Mhz
32.0000-33.0000 Mhz
34.0000-34.9900 Mhz
36.0000-36.9900 Mhz
38.0000-38.9900 Mhz
40.0000-41.9900 Mhz
46.5800-47.0000 Mhz
49.6100-49.9900 Mhz
138.0000-144.0000 Mhz
148.0000-150.8000 Mhz
Steve08CVPI
I would expect anything the Army is transmitting is gonna be encrypted
N9JCQ
Lake Barrington, IL
I can only copy a little Wisconsin area traffic from my NE ILL location but my money would be that WIANG is using a talkgroup on WISCOM if they'd be anywhere. I can't find any TGs specifically calling out the WI Army NG or Air Guard. But perhaps they are using those related to EMTs or similar. Just a thought. I lnow ILANG has access to Starcom21 down here
CrabbyMilton
Last night I heard them on 40.900mhz in Milwaukee. Not sure but I think it was coming from the Blackhawk helicopter that was flapping around.
mws72
Quad-Cities (IA-IL) USA
Down here in the Davenport Iowa area. In the past I heard the Wi ANG helicopters on 148-150 range. Sorry it been a while and I keep lousy notes.
OpSec
All your WACN are belong to us
Monitoring the database
Most of the Guard units are talking to each other on freq-hopping SINCGARS, so you're not going to catch anything there. There is some single-frequency use but a lot of crypto as one would expect.
.mil AM aircraft channels are still out there for listening when in the area.
MarcusDude
Appleton, Wisconsin
I decided to take a drive by the National Guard armory in Appleton, and noticed they have an antenna on a pole on their roof. I wasn't able to take a picture, but I found this on Google Earth Street View. It looks to me to be a vertical antenna on the end of a pole, but there are 2 elements across it in the shape of an X (some sort of discone perhaps?). Any idea what type of antenna this is, or what bands/modes it could be used for?
87981
ChrisP
Portland, OR
That looks like an OE-254/GRC low-band FM antenna, 30 - 88 MHz.
- Chris
eg1451
Heard "ARMY 206" on WISCOM TG 8498 radio ID 8409128 talking about Milwaukee approach and asking for Wisconsin Aviation for fuel
