Ashtabula PD?
scnrfrq
Erie, PA
Anyone know how to listen to Ashtabula PD? They are listed in he database as using 769.53125 MHZ. Can I just create a favorites list with that frequency? Anything else?
Enforcer52
Voice Of The Piney Woods
Lake Livingston, TX
Yes, has to be set to P25 conventional channel.
What scanner you using? And 40 miles away not sure if it will pick up from Erie, unless you are a lot closer than Erie and have a good outdoor antenna.
scnrfrq
Erie, PA
Have 436, 536, and SDS200. Really asking for friend in Madison though. About 18 miles.
No outdoor antenna.
Enforcer52
Lake Livingston, TX
If your friend is in Madison, Ohio, shouldn't be a problem to pick up Ashtabula PD as long as setup as conventional P25.
scnrfrq
Erie, PA
Working on setting it up on a 996. Not sure how exactly. I set it as a P25 one frequency system with one site. Its now on ID search. Is this correct?
scnrfrq
Erie, PA
I now see there is a conventional option too. I set that up with Ash PD as the system, and Group 1 as Ash PD Dispatch. When scanning it shows the system as Ash PD, and Group 1 is active. But Ash PD Dispatch doesn't show when scanning. Is this OK? Just want to be sure since I'm aways away, and distance could be a factor.
wa8pyr
Lead Database Admin
Ohio
Just program it as a conventional frequency, select P25 as the mode (if that option is available), and 293 NAC. No groups or anything fancy.
